Printer Model: Ender 3
MCU / Printerboard: GD32F 303? Creality Board v4.2.2
Host / SBC: Raspberry Pi 4 Model B 8 GB RAM
klippy.log (339.3 KB)
I keep getting:
dfu-util: Warning: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release
dfu-util: No DFU capable USB device available
Failed to flash to 1eaf:0003: Error running dfu-util
If the device is already in bootloader mode it can be flashed with the
following command:
make flash FLASH_DEVICE=1eaf:0003
OR
make flash FLASH_DEVICE=1209:beba
If attempting to flash via 3.3V serial, then use:
make serialflash FLASH_DEVICE=1eaf:0003
make: *** [src/stm32/Makefile:111: flash] Error 255
when I try flashing it with the menu config options:
[] Enable extra low-level configuration options
Micro-controller Architecture (STMicroelectronics STM32) —>
Processor model (STM32F103) —>
[ ] Only 10KiB of RAM (for rare stm32f103x6 variant)
[] Disable SWD at startup (for GigaDevice stm32f103 clones)
Bootloader offset (28KiB bootloader) —>
Clock Reference (8 MHz crystal) —>
Communication interface (Serial (on USART1 PA10/PA9)) —>
(250000) Baud rate for serial port
() GPIO pins to set at micro-controller startup
Is there a boot loader mode that I have to be in? Any help is appreciated.
