Flashing is not working for ender 3v2
Printer Model: Ender 3V2
MCU / Printerboard: 4.2.2 with GD
Host / SBC Raspberry PI V3
klippy (3).log (111.9 KB)
I started the “make”, copied the .bin (named fw0406.bin) to a sd, and started the printer, without connection to the pi or the display.
After a while, I switched the printer of, dismounted the sd-card, connect the usb to the raspberry, and powered on again.
on the minimon I got the message
Update failed, No SD/TF-Card or error
and the printer is clicking 4 times.
So i deleted the fw0406.bin, and copied the marlin fw to the sd. (without usb) after a view moments the marlin sw start, without any problems.
the filesize of the fw ist 38kByte.
What do I make wrong?
thx Dirk
Did you even try to connect the Pi to the MCU before flashing back?
SSH in and use kiauh to find the MCU or run ls /dev/serial/by-id/*.
I don’t know for sure what display you have but many won’t work before Klipper initializes the MCU with info from a valid printer.cfg file.
EDIT: apparently getting your stock display to work under Klipper takes some work.
Yes I read a lot,
but I tested a zip file here from the forum which was nearly working, but the version was to old.
Then I got in mind that perhaps the transfer via winscp ist the problem:
BINGO
I made a tar out of the bin. downloaded it, extracted the tar and copied the bin to sd-card.
And : ABLOUSE.
the connection was astablished. It was one day of work.
Frohe Ostern1
Glad you got it sorted out!
Please mark your last post as the solution.
