Flashing/USB connection issue
Printer Model: Ender3 NG
MCU / Printerboard: SKR Mini E3 v2
Host / SBC: Rasp Pi
…This has been an issue that started a couple years ago but I just shelved the project because it was frustrating and costing time and money. Ive tried to install Klipper on an skr 2, skr 1.4 turbo, creality 1.1.4 board, sunlu s8 and an skr mini e3 v2. The only one I have been successful with are the stock sunlu and creality boards. The BTT boards all seem to flash, have .cur file afterwards but can not be seen by usb. So I can never get the ID to continue to setup klipper. I have tried multiple sd cards, cables and computers. Same issue. The only one issue Im pretty sure may have been my issue was the recent skr mini e3 v2 board I didnt select !PA14 for the GPIO pins. Also I cant get any of them to connect with my stlink usb tool. Im currenlty switching cables on the stlink to verify that the diagram isnt just reversed. Also verified chips on board are the correct versions and not the variants. (SKR mini shows stm32 not GD and SKr 1.4 turbo shows the 1769 ).
Does anyone think they can assist or do I just have really bad luck with BTT boards?
If I forgot to select !PA14 in the options to flash would that prevent me from using the usb? (I have tried reflashing with correct setup but same issue. .cur file but no connection)
I just really cant believe I can flash 3 other stock mainboards correctly but these BTT Im just screwing up somehow.
Thanks
f407 or f428?
I’d flash both boards to stock marlin (straight from BTT) and see if they connect to USB?
Where did you obtain these boards? Pulled from dead printers?
The chip is stm32f103 if thats what you mean.
The boards where new from amazon. The SKR mini e3 v2 is the most recent Ive had an issue with and it was installed and was working on my ender 3 pro.
