FLSun Super Racer and Input Shaper
Has anyone managed to run Input Shaper on a super racer and get a good result. I’m pulling my hair out on this one. I checked to make sure everything movement related is tight yet after applying the recommended shaper, I still get horrific ringing.
Any assistance would be welcome.
I have no experience with deltas.
Graphs with the properties:
  • Pretty low Power Spectral Density, i.e. below 1e4
  • Peaks starting from 0 Hz or Frequencies below 25 Hz
point to a problem in the motion system, e.g. binding axes etc, at least on a Cartesian printer. Manged to produce this effect on my own printer already when working on the Y axis and seen other people graphs, too.
As initially pointed out, no clue if it applies to Deltas as well.
