Getting an error that 'Step_Pin" must be specified, but it already is?
Printer Model: Custom Delta
MCU / Printerboard: SKR MINI E3 V3
klippy log.txt (172.9 KB)
I’m working with an old Delta printer that I ripped the electronics out of and have been upgrading to Klipper via a SKR Mini e3 v3. I wrote the attached config file based off of the example configs for delta printers and the skr mini e3 v3. I’ve been getting the error “Option ‘step_pin’ in section ‘stepper_a’ must be specified” but I have it defined in my config, so what’s going on?
The error is a little confusing because Klipper is looking for a stepper_a section, but it’s not there. The reason it’s looking for stepper_a is because you changed the kinematics to delta, but right now you have X,Y, and Z defined instead of A,B, and C.
I should note you previously had the kinematics defined as cartesian which is why you didn’t see the error until the last restart in the log.
Whoops, I feel a little dumb, I went and fixed the X/Y/Z stepper labelling to A/B/C but it didn’t get sent, I restarted and re-sent the new config and that error went away.
I updated the uart addresses for the steppers too, but now I’m getting a weird M112 error
I’ve attached my updated log file
klipper log corrected.txt (8.4 KB)
You need the full path to the serial device in your config.
This:
serial: usb-Klipper_stm32g0b1xx_1100240012504B5735313920-if00
Should be this:
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_1100240012504B5735313920-if00
