Getting skewed print why?
I recently configured my printer with klipper firmware and it is printing skewed parts.
printer.cfg (4.0 KB)
printer is printing fine if i install marlin, so hardware is perfectly fine.
Skew current is not enabled .
How much is it skewed? How did you measure?
I measured the diagonal length, the difference is 10 mm (in theory it should be same)
10 mm is quite much.
Skew is caused by mechanical misalignments.
What printer do you use?
You may run this:
http://www.klipper3d.org/Skew_Correction.html
I installed marlin and it is printing perfectly okay .
Not a mechanical problem i guess.
I saw at the config that you run as corexy.
So the settings of [stepper_x] and [stepper_y] should be quite identical,
but have a look on the microsteps of [stepper_x]. There is only 30 instead of 32.
thanks it worked.
it was typo :slight_smile:
