Having issues getting BLTouch to work (constantly triggered status)
Printer Model: Custom CoreXY
MCU / Printerboard: Duet 2 Wifi
I’m currently in the process of setting up Klipper on my Duet 2 WiFi board, however my Z endstop status is stuck on TRIGGERED always. I can communicate with the probe and send, up, down etc query commands so it would seem that control_pin is fine but sensor_pin is not working?
I have it hooked up to the probe pin PC1 as per duet documentation.
Config section is below.
[bltouch]
sensor_pin: PC1
control_pin: PA15
stow_on_each_sample: False
This determines if Klipper should command the pin to move up
between each probe attempt when performing a multiple probe
sequence. Read the directions in docs/BLTouch.md before setting
this to False. The default is True.
probe_with_touch_mode: true
z_offset: 3
x_offset: 20
y_offset: -5
pin_move_time: 0.3
speed: 16
lift_speed: 16
samples: 1
samples_result: median
sample_retract_dist: 5.0
samples_tolerance: 0.01
samples_tolerance_retries: 3
I also don’t know if I need to edit anything on Z stepper
step_pin: PD8
dir_pin: PD13
enable_pin: !PC6
microsteps: 64
rotation_distance: 10
endstop_pin: ^PD29
#endstop_pin: PD10 # E0 endstop
#endstop_pin: PC16 # E1 endstop
position_endstop: 0.5
position_max: 235
homing_speed: 50
console log:
10:17 PM
probe: open
10:17 PM
QUERY_PROBE
10:17 PM
x:open y:open z:TRIGGERED
10:17 PM
QUERY_ENDSTOPS
10:15 PM
10:15 PM
QUERY_ENDSTOPS
7:58 PM
7:58 PM
QUERY_ENDSTOPS
I guess when you filled out this post, you somehow missed this:
Which is strange because you put in all the requested information above the need for you to attach the klippy.log.
sorry… I did miss that.
Attached
klippy.log (3.1 MB)
I couldn’t find accurate schematics for the Duet 2 Wifi so you might have to play with the values a bit. Do you know the version of the board that you have?
First off, in your [stepper_z] statement why do you have endstop pin = ^PD29 defined? Isn’t your Z axis endstop the BL Touch (which is a “probe”)? I’m not sure how (or if) they will work together.
To get ONLY the BL Touch working, you need to change the endstop pin = ~PD29 parameter to endstop_pin: probe:z_virtual_endstop to pick up the BL Touch.
Along with specifying the endstop_pin probe, change your sensor_pin = PC1 parameter in the BL Touch statement to sensor_pin = ^PC1 to enable the internal pull up in the MCU as the BL Touch pin is open collector/open drain.
Is it a genuine BLtouch or some clone?
Also: For what do you use the BLtouch?
Not for homing:
step_pin = PD8
dir_pin = PD13
enable_pin = !PC6
microsteps = 16
rotation_distance = 8
endstop_pin = ^PD29    # <---
position_endstop = 0.5
position_max = 200
And not for the bed mesh:
There is no [bed_mesh] macro.
Yeah this is a genuine BLtouch 3.1. My duet is a Wifi 1.02 genuine board as well.
Thank you for the pointers, I knew it had to be something with stepper_z config but I wasn’t sure what to put there, so now it’s no longer showing triggered after adjusting probe:z_virtual_endstop
Also, yeah there was no bed mesh macro as I hadn’t even got that far yet, was trying to get the probe to work first.
But now, i’m getting a new error when homing
“BLTouch failed to verify sensor state; retrying.”
I can still send pin up / pin down and that all works fine though.
edit, ok i added
pin_up_touch_mode_reports_triggered: False
And now it starts to home.
edit2, ok so it still does not actually trigger once the pin is pressed.
I did change my sensor pin pullup
[bltouch]
sensor_pin: ^PC1
control_pin: PA15
edit3, ok so all I did was flip the black and white wires on the PC1 / probe pins and NOW it triggers? strange. moving onto setting up bed mesh.
