Help Can't communicate to the MCU via serial port
Printer Model: Custom Delta
MCU / Printerboard: Arduino Due
mcu ‘mcu’: Unable to open serial port: Could not configure port: (5, ‘Input/output error’)
Hello I am using Klipper with Moonracker and Fluid. I am using a Banana Pi connected to an Arduino Due.
When I connect the Banana Pi via USB to the Arduino Due everything works as intended but when I try to use the serial port instead, I got this error, and I can’t find what to do:
I have tried different serial port and to use different Banana Pi and Arduino Due
i already asked this question on reddit here : Reddit - The heart of the internet
Thank you for your help !
did yo find a solution. having a similar issue
You’re going to need to start your own thread and post all the required information in the form, including your klippy.log.
