Hi !
I need to do some temperature tests with my RP2040 board. And I want to calculate graphs from the klippy.log for this purpose. Problem is that the Stats logging is disabled in klippy.log when the printer is not active.
So is there any way - configuration or changing some lines of python code - to have the STATS logging even running when the printer is in idle mode?
I know this will result in a huge log file. But as mentioned above … It’s only for testing purpose and not for daily usage.
no I don’t think so. The logging of stats information is disabled when the printer is in idle. So regardless which frontend you are using, you won’t get any data at all.
