Hi everybody,
because the only known solution for iOS is the expensive and ugly software MochaX11.
I was creating a simple Solution for RemoteDesktop like the free Microsoft RemoteDesktop Application.
So it’s very simple. I will use default home dir /pi/ change with your username
First of all we have to Install KlipperScreen like in the docks, after that install xrdp
sudo apt install xrdp
Now you have to create an file in your home path called .xsession use your prefered file editor I’m using vim
vim /home/pi/.xsession
The file should contain these two lines.
cd /home/pi/KlipperScreen
exec /home/pi/.KlipperScreen-env/bin/python /home/pi/KlipperScreen/screen.py
To make restart usable you have to edit /home/pi/KlipperScreen/screen.py
Change line 438 from
os.system("sudo systemctl restart KlipperScreen")
to
os.system("sudo systemctl restart xrdp")
reboot your pi or restart xrdp (sudo systemctl restart xrdp)
Thanks for this simple solution
Works with my iPad or even 7" Fire tablet from 2015
Any suggestions for an Android RDP client? The Microsoft one won’t let me set a lower custom resolution…
I think this method should be part auf the KIAUH installer, so easy and useful for old phones and tablets.
What i did:
nano /home/pi/.xsession
Paste this 2 lines:
ctrl+x
Create a new KlipperScreen.conf from Mainsail UI (where your printer.conf is) paste and save:
[main]
service = xrdp
Reboot the pi and connect with your username and password in your RDP app of choice.
I was able to get it working on my iPhone but the resolution is way off and I can only see part of the interface. I tried changing resolution in the RDP app but nothing changes. Is there somewhere in KlipperScreen that you have to set the resolution to make it display properly?
