As the title says I need a command that allows me to control the extrusion and feed rate at the same time based on a variable. I don’t know the syntax though.
but this results in the F{linear_speed} not being seen.
Another question is the extrude rate even effected by the speed “F” at all? I assumed it does but if not please let me know.
Really I just need to keep the overall extrusion rate constant while having the ability to adjust the linear_speed as a parameter. Any help would be appreciated. Thank you.
I have a spinning shaft I’m printing on that moves back and forth to make a cylindrical mesh stent. Think of a Chinese finger trap.
I’m not using a slicer at all and am doing the programming myself. I adjust the linear speed to see what properties of the stent changes. However, if the extrusion rate is dependent upon this linear speed, “F” value, then I need to be able to adjust the “E” in order to keep the extrusion rate constant.
Thus I have this dilemma of changing the linear speed, which changes the extrusion rate because they are based on one another. I can keep the extrusion rate constant if it changes as a function of the linear speed.
It would help to see your entire macro and an example of how you’re calling it. In the code snippet you posted the ‘extrude_rate’ variable is calculated but never used for anything.
Down in the macro with the for loop section is where I need extrude rate to be constant no matter what I change the linear_speed to. However, if I have the command written as:
G1 Y180 E{extrude_rate} F{linear_speed}
instead of:
G1 Y180 E0.1 F{linear_speed}
I get an error and it doesn’t allow me to have a variable with the E value but with just the F value it works fine. I could go in and change it every single time but then I have to restart the machine and reheat everything and it takes a lot of time.
Heres the full macro:
[gcode_macro LIN_X]
variable_extruder_temp: 150 #Celcius
variable_shaft_speed: 63.32 #rpm
variable_numpass: 7 #number of back and forth passes
variable_length: 10 #length of stent in mm
#variable linear speed, need to be able to change this
{% set linear_speed = params.LIN|default(200)|float %}
#keeps extrusion rate constant based on the linear speed
{% set extrude_rate = (20/linear_speed) %}
#code for calculating how long to turn the spindle on
{% set move = ((120 * length * numpass / linear_speed + 26) * shaft_speed %}
# Homes printer
M117 Homing...
G28
# Gets extruder ready
M117 Heating up extruder...
M109 S{extruder_temp}
G92 E0
# Sets coordinate systems for xyz and extruder
G90
M83
# Moves to initial position
G1 X153.3 Y160 Z27.3 F3000
# Turns spindle on
MANUAL_STEPPER STEPPER=shaft ENABLE=1 SET_POSITION=0 MOVE={move} SPEED={shaft_speed} SYNC = 0
# Initial contact with spindle
G1 162.5 E0.8 F20
G1 Z29 E0.1 F100
# Turns fan on for cooling
SET_FAN_SPEED FAN=shaftfan SPEED=0.5
# Moves back and forth 10mm for n number of passes
{% for i in range(numpass) %}
# this is where I want to be able to control both the extrude rate
# and linear speed in order to keep it constant. I am changing
# linear speed everytime, but want extrude_rate to change
# as linear speed changes
G1 Y168.5 E{extrude_rate} F{linear_speed}
{% endfor %}
# Homes itself and turns off extrusion and fan. Stent is finished
G92 E0
G1 Y160 F{linear_speed}
G4 P1000
G1 X0 Y0 F3000
G1 Z0.5 F3000
M117 Finished!
Nevermind, I’m dumb and it works just fine. My monkey brain assumed that the “F” turning red in the printer.cfg was a bad thing. It seems to just be able for the user to differentiate from the “E” to the “F” because they were normally both the same color, until you add a variable to the “E”. This makes no sense unless you actually have this code pulled up in the Klipper code editor. Thanks to anyone who replied.
