Printer.cfg vs slicer profiles
It seems like a lot of the tuning params (like pressure_advance) are specified in printer.cfg, but (may) vary with temperature and filament type. Is there a way to set PA specifically – and other parameters more generally – via custom g-code in the slicer config?
All supported g-codes are at this link.
For pressure advance you would use SET_PRESSURE_ADVANCE EXTRUDER=<config_name> ADVANCE=<pressure_advance>
Thanks, Jake. I’ll update here if I find any others that are relevant. I thought there was at least one aside from the pressure advance, but I’m blanking on it, now. :slightly_smiling_face:
All the parameters that can be controlled from Gcode in the slicer are in the Gcodes document.
Gcodes
I like to have this options in printer.cfg so I don’t need to resclice that much…
#rotation_distance: 26.71 #ABS
rotation_distance: 25.114 #PLA
#rotation_distance: 26.185 #wood
pressure_advance: 0.046665 #PLA
#pressure_advance: 0.06665 #petg
rotation_distance is reflecting the properties of your mechanical system and IMO should not be used to tune filament specific properties.
You can use macros to switch filaments and use:
SET_EXTRUDER_STEP_DISTANCE
Refer to the link posted by @jakep_82 for the command and to @mental excellent macro tutorial: Macro Creation Tutorial
as the filaments I use have a little bit different structures and diameter-tolerances do a calibrating (measure and extrude 100mm) with each filament-type and as I get different results I could change the feedrate in slicer or at the printer or I can change the rotation_distance
same for pressure advance as all this stuff depends on the filament (and extruder and hotend and environment)
I don’t say it’s the best solution for everyone to set this options in printer-cfg but I like it
and at most I like to have the option - thank you klipper
if you may use different sclicers and test and change a lot it’s sometimes good to know some parameters are ‘always correct’ :wink:
oh and another great option is to use SET_EXTRUDER_STEP_DISTANCE, SET_PRESSURE_ADVANCE, etc. in you start-macro so it’s all at one place
