How to read "adc_temperature" value in Macro
Printer Model: N/A
MCU / Printerboard: Custom STM32G0B1 board
Host / SBC: CM4
klippy.log / NA
In my functional test macro, I’m trying to read an adc_temperature sensor.
On my board, there are three “temperature” sensors (two being actual temperature sensors and one being a voltage monitor circuit (PS_voltage). I’ve defined them as:
[heater_generic heater0]
#gcode_id:
#   The id to use when reporting the temperature in the M105 command.
#   This parameter must be provided.
heater_pin: PD6  #$# HEATER0
#max_power:
sensor_pin: PA0  #$# THERM0
#smooth_time:
control: pid
pid_Kp: 67.552
pid_Ki: 1.603
pid_Kd: 711.829
min_temp: 0
max_temp: 60
#   See the "extruder" section for the definition of the above
#   parameters.
[heater_generic heater1]
#gcode_id:
heater_pin: PB3  #$# HEATER1
#max_power:
sensor_pin: PA1  #$# THERM1
#smooth_time:
control: pid
pid_Kp: 67.552
pid_Ki: 1.603
pid_Kd: 711.829
min_temp: 0
max_temp: 60
#   parameters.
[adc_temperature PS_voltage]
# PSU Voltage Value from Thermistor Value
# Assumuptions:
# 1. Power Supply Voltage from 0V to 70V
# 2. Thermistor ADC Pullup 4.7k
temperature1: 2
voltage1: 0.151
temperature2: 70
voltage2: 3.049
[temperature_sensor PS_voltage]
adc_voltage: 3.3
sensor_pin: PA2  #$# VINMON
sensor_type: PS_voltage
min_temp: 11  # For 12V Power Supply
max_temp: 26  # For 24V Power Supply
gcode_id: PS_voltage
To read them and display their values, I use the macro code:
RESPOND TYPE=command MSG="Test1: Heater0 Temperature: { printer["heater_generic heater0"].temperature }"
RESPOND TYPE=command MSG="Test1: Heater1 Temperature: { printer["heater_generic heater1"].temperature }"
RESPOND TYPE=command MSG="Test1: VINMON Voltage { printer["adc_temperature PS_voltage"].temperature }"
heater0 and heater1 return values without issue (and match what is shown on the Mainsail Dashboard) but the RESPOND line for PS_voltage causes the error:
I’ve looked through klipper/klippy/extras and it looks like the other temperature python objects have a get_status method which is accessed by the macro processor whereas adc_temperature does not.
I think all that’s needed to return the temperature value is to add the following get_status method to klipper/klippy/extras/adc_temperature.py in the PrinterADCtoTemperature class:
        return {
            'temperature': round(self.last_temp, 2),
Would this be correct?
The temperature is in the temperature_sensor PS_voltage section: Status reference - Klipper documentation
Hi Kevin,
Thanx for the reply - now when I look at the link:
There is no temperature_sensor PS_voltage section - I’m not sure what you mean by it.
I’m trying to work it out on my own (with the change above and variations) but not having any luck.
I realized that last_temp wasn’t used in adc_temperature.py so I’ve changed it to just temp and also added the min/max temperatures without any luck ie:
        return {
            'temperature': round(self.temp, 2),
            'min_temp': round(self.min_temp, 2),
            'max_temp': round(self.max_temp, 2)
Any idea what I’m doing wrong?
I’ve been through the klippy (1).log (1.4 MB) and can see that the problem is at line 61 of /home/biqu/klipper/klippy/extras/gcode_macro.py which is:
return str(self.template.render(context))
Thanx for answering.
In the config snippet you posted you have a [temperature_sensor PS_voltage] config section. That config section should produce a printer["temperature_sensor PS_voltage"].temperature variable that is accessible from gcode macros. It’s documented in the link I posted above. Sometimes there are weird things with case sensitive names - you might want to double check that.
You definitely don’t need to modify the code. Everything that mainsail/fluidd sees is available to macros - if you see the temperature in the GUI it’s available to the macros.
Hope that helps,
Okay, I changed the line in the macro to:
      RESPOND TYPE=command MSG="Test1: VINMON Voltage { printer["temperature_sensor PS_voltage"].temperature }"
I also removed the added code in adc_temperature.py and stopped/started the klipper service.
And that worked a treat:
I don’t know if it will be helpful to anybody down the road but the issue is how I visualized the printer.cfg adc_temperature statement.
I treated adc_temperature as the device and not the modifier/descriptor of temperature_sensor.
To make the relationship clearer, I’m going to move adc_temperature to below temperature_sensor.
Thank you for explaining that.
EDIT:
When I reversed the order of the adc_temperature and it’s corresponding temperature_sensor statements and hit SAVE & RESTART I got:
So, I guess this is a case where the order of the statements in printer.cfg matters.
The order of the two statements above is the correct one.
