Jonas
January 10, 2023, 7:49pm
1
I have a question how to add the stm32 temperature sensor in klipper?
Easy peasy, add the following statement to your printer.cfg:
[temperature_sensor mcu_temp]
sensor_type: temperature_mcu
min_temp: 0
max_temp: 100
I’ve defined the controller as “mcu”, as in:
serial: /dev/serial/by-id/usb-Klipper_stm32f407xx_##UNIQUE#USB#SERIAL#HERE##-if00
Jonas
January 11, 2023, 11:44am
3
Thank you but I tried this already. I have a BTT SKR3 and when i add the sensor it answers ADC_TEMPERATURE not found.
Please post your klippy.log
You have:
sensor_type = temperature_mcu
min_temp = 0
max_temp = 100
I believe it should be:
min_temp: 0
max_temp: 100
It looks like you’re using an equals sign (“=”) when you should be using a colon (“:”). It seems like you use equals everywhere - I think you need to go through your .cfg files and make sure you have the correct statement assignment character.
Jonas
January 11, 2023, 1:52pm
7
Thats strange when I look in my printer.cfg I have (“:“).
And that is the Klipper error:
Pin ‘ADC_TEMPERATURE’ is not a valid pin name on mcu ‘mcu’
Printer is halted
It seems that at some point the colons are replaced. Sorry about that.
Now, your rPi temperature_sensor looks funny. Mine is:
[temperature_sensor raspberry_pi]
sensor_type: temperature_host
min_temp: 10
max_temp: 100
Could that be the problem?
Jonas
January 11, 2023, 2:13pm
9
With deleting the RPI Sensor the problem is still the same. I dont now why the MCU Temp Sensor dont work but its not so important for me. Maybe a Klipper patch in future can fix it.
Sineos
January 11, 2023, 3:23pm
10
Function-wise both are treat equal. As “configuration policy” the colon is preferred
Sineos
January 11, 2023, 3:33pm
11
WRT to the H7 MCU temperature, there seem to be some discussions in various pull requests, e.g.
Klipper3d:master ← Klipper3d:work-stm32h7adc-20221212
opened 08:06PM - 13 Dec 22 UTC
The stm32h7_adc.c code is used on a number of chips now - stm32g431, stm32l412, … stm32h723, stm32h743, and stm32h750. The adc code had a lot of ifdefs and slightly different behavior between chips. Most of these differences were unnecessary. This PR reworks the code to use less ifdefs.
I found and (hopefully) fixed a few bugs while doing this:
1. The stm32l412 should not use CKMODE=0.
2. On stm32h7 the adc actually runs at 25Mhz so the code should use BOOST=0b10.
3. The ISR clear of ADRDY should use explicit writes instead of read-modify-write.
I have also reworked the code to use explicit register writes where practical (instead of read-modify-write).
I have tested this on stm32h723. I don't have stm32l4, stm32g4, stm32h743, nor stm32h750 chips to test.
@D4SK , @adelyser, @mattthebaker, @bigtreetech - FYI.
Klipper3d:master ← adelyser:stm32h743_mcu_temp_fix
opened 04:30AM - 17 Aug 22 UTC
module: stm32h7 ADC
Fix mcu temperature on SKR-3
Signed-off-by: Aaron DeLyse… r [bluwolf@gmail.com](mailto:bluwolf@gmail.com)
Jonas
January 11, 2023, 4:11pm
13
The solution is to change two files, wich @Sineos found on GitHub:
Here are the two files if anyone need it:
STM32H7_MCU_FIX.zip (4.7 KB)
One file is located in /home/pi/klipper/src/stm32 and the other one in /home/pi/klipper/klippy/extras.
Thanks for your help!
