How to turn off extruder stepper
Printer Model: Custom
MCU / Printerboard: Manta M8P
Host / SBC CB1
klippy.log No
I have noticed that my extruder motors keep turned on (energized) after printing, and i’d like to turn them off just like one can turn off an stepper.
Does SET_STEPPER_ENABLE work for this or this should be done in other way?
Thanks in advance
Why not?
Have you included a M18 or M84 at the end of your print file (slicer, END_PRINT macro)?
https://reprap.org/wiki/G-code#M18:_Disable_all_stepper_motors, G-code - RepRap
Well, because it’s just a question for development, not searching help by some bug or similar…
No, i don’t use m18 or m84 at the end of the print as i dont want to disable all motors as i would need to home again the printer in order to move it, and i dont want to do that. Instead i disable them only in my timeout.
I’d like to just disable my extruder steppers whenever I want, if it is possible.
M84 E can be used as well, in short it disables just the extruder motor, But yes SET_STEPPER_ENABLE stepper=extruder enable=0
will disable it too. But fyi some mobo’s share one enable for all the motors… some ender’s did (see link)
You can use M18 E or M84 E
As described in the links
I’ll take a look. Thanks!
Hey guys. This doesn’t work, it disables all motors. I tried M18 E
Maybe you should test:
M18 E0
Ok, i’ll try.
Also, i have two extruders (idex printer). In order to reset T1, do i need to place M18 E1 too?
In Klipper, M84 and M18 disable all motors. Use the SET_STEPPER_ENABLE command to disable individual motors. G-Codes - Klipper documentation
Thanks Kevin!
