onsight
November 10, 2025, 7:33pm
1
Printer Model:ender 3v2
MCU / Printerboard:skr mini e3 v2.0
…I installed klipper and done my pid tune and z offset fine but when i go to print the sprite extruder gear don’t don’t turn.
I have installed marlin again and the extruder works fine,so please can someone have alook at my printer.cfg and help me.
Also the step_pin: PB4
dir_pin: PB3
i have swapped with each other as that what google said pin layout was but i have tried both ways.
Thank you
klippy.log (2.5 MB)
printer.cfg (3.1 KB)
Hello @onsight !
As for this:
it should be:
step_pin = PB3
dir_pin = PB4
enable_pin = !PD2
onsight
November 10, 2025, 8:11pm
3
Hi thank you for reply but i have also tried that but extruder gear don’t move.
At the moment i have gone back to Marlin and extruder works fine,i just don’t get it as i been at it all day.
Hopefully someone can help
onsight
November 10, 2025, 8:17pm
4
here is my other printer.cfg. Still no dice
config-20251108-171248.zip (1.5 KB)
Other printer.cfg?
Anyway, the enable_pin is still the same:
step_pin: PB3
dir_pin: !PB4
enable_pin: !PD1
It should be !PD2
onsight
November 10, 2025, 8:35pm
6
Why does my extruder gear not turn but work fine on marlin firmware ?
Maybe the enable_pin is different than your settings in Klipper.
So - have you tried enable_pin: !PD2 ?
onsight
November 10, 2025, 8:48pm
8
no i have not tried that,also could it be wrong rotational distance for sprite extruder ?
No, it’s the wrong enable pin you use.
onsight
November 10, 2025, 8:51pm
10
I will tey !PD2 tomorrow as just started a print. Im really hoping it is that as looking foward to using klipper mate
onsight
November 10, 2025, 8:57pm
11
i used the skr mini e3 v2 example printer.cfg from github and it was !PD1 on there.
onsight
November 10, 2025, 9:05pm
13
my mistake it is !PD2 in the example priter.cfg. I really don’t get how i got !PD1.
Thank you for helping me with this silly mistake of mine. Hopefully tomorrow i will be able to print using klipper.
Thanks again pal
Maybe you picked the V3, there ist is !PD1
onsight
November 10, 2025, 9:07pm
15
Yh i think your right, in that case do i have to change anything else pal ?
I don’t think so. You may try and report back later.
onsight
November 10, 2025, 9:10pm
17
To be on safe side without more drama i will just start a fresh skr mini e3 V2 printer.cfg as i only added my rotational distance and start,end macro
onsight
November 12, 2025, 7:20pm
18
Thank for the help pal. Really appreciated your time and help as all sorted now.
