Idle_timeout not triggered when using delayed_gcode
Printer Model: LDO Voron 2.4 RevD
MCU / Printerboard: Leviathan
Host / SBC: Raspberry Pi 4
klippy.zip (3.1 MB)
I have been at this for days and cannot get to the bottom of the issue.
I have idle timeout configured:
idle_timeout
IDLE_TIMEOUT
timeout: 1800
but it never fires, manually running my macros work as expected, so I read the docs and using the API explored states.
When my print completes the state transitions is correct as standby or idle
GET ``http://voron24.local/printer/objects/query?print_stats
"result": {
"eventtime": 147363.244125516,
"status": {
"print_stats": {
"filename": "",
"total_duration": 0.0,
"print_duration": 0.0,
"filament_used": 0.0,
"state": "standby",
"message": "",
"info": {
"total_layer": null,
"current_layer": null
When I query idle_timout however it always remains ‘printing’
GET ``http://voron24.local/printer/objects/query?idle_timeout
"result": {
"eventtime": 147508.385373504,
"status": {
"idle_timeout": {
"state": "Printing",
"printing_time": 4582.452879657998,
"idle_timeout": 1800.0
This is true regardless of what I do, even after a complete restart or power cycle, the state is always printing.
I cannot find any hints in the documentation of what I can possible have misconfigured and I also don’t see anything useful in the logs that hinting at possible errors in my setup.
Any pointers will be much appreciated.
I found the root cause, by inspecting the idle_timout python code the blinking LED’s I implemented kept the toolhead PCB busy and reported printing due to the delayed gcode implementation of switching hardware.
Digging deeper it transpires that ANY delayed_gcode calls causes this behaviour, so all delayed gcode should be turned off post print to trigger idle_timeout.
[IdleTimeout] get_status called: state=Ready, printing_time=0.0, idle_timeout=1800.0
[IdleTimeout] handle_sync_print_time called: curtime=1744.818620885, print_time=1754.2186728525, est_print_time=1754.4686728525, state=Ready
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/reactor.py”, line 387, in _dispatch_loop
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/reactor.py”, line 184, in _check_timers
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/extras/delayed_gcode.py”, line 34, in _gcode_timer_event
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/gcode.py”, line 241, in run_script
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/gcode.py”, line 223, in _process_commands
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/gcode.py”, line 151, in
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/gcode.py”, line 161, in
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/gcode.py”, line 336, in _cmd_mux
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/extras/fan_generic.py”, line 43, in cmd_SET_FAN_SPEED
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/extras/fan.py”, line 72, in set_speed_from_command
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/extras/output_pin.py”, line 66, in queue_gcode_request
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/toolhead.py”, line 529, in register_lookahead_callback
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/toolhead.py”, line 323, in get_last_move_time
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/toolhead.py”, line 267, in _calc_print_time
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/klippy.py”, line 227, in send_event
[IdleTimeout][STACK] File “/home/jattie/klipper/klippy/extras/idle_timeout.py”, line 106, in handle_sync_print_time
[IdleTimeout] State transitioned to Printing, updating timer, check_time=0.25
[IdleTimeout] get_status called: state=Printing, printing_time=0.03806874099996094, idle_timeout=1800.0
[IdleTimeout] timeout_handler called: eventtime=1745.069032811, state=Printing
[IdleTimeout] timeout_handler: print_time=1754.4686728525, est_print_time=1754.4690821225, lookahead_empty=True, buffer_time=-0.00040926999986368173
[IdleTimeout] Buffer time > -READY_TIMEOUT, waiting
[IdleTimeout] get_status called: state=Printing, printing_time=0.28829585199991925, idle_timeout=1800.0
You can implement blinking LED:s via the template system. This way you can create blinking effects without delayed macros.
You first need to create a template with built in blinking animation. We are using the printer.toolhead.estimated_print_time to get a timestamp that’s used for the blinking.
[display_template my_blinking_led]
param_red: 0
param_green: 0
param_blue: 0
param_white: 0
text:
  {% set frame = (printer.toolhead.estimated_print_time|int % 2) %}
  {frame|float*param_red}, {frame|float*param_green}, {frame|float*param_blue}, {frame|float*param_white}
Then you can set/activate the template to a led via the SET_LED_TEMPLATE command and it will blink all by itself without delayed macros or help. You can send the colors as parameters for the template.
# Set red color blink
SET_LED_TEMPLATE LED=rgb_light INDEX=1 TEMPLATE=my_blinking_led param_red=1
# Set green color blink
SET_LED_TEMPLATE LED=rgb_light INDEX=1 TEMPLATE=my_blinking_led param_green=1
If you want to turn of the led or change to a solid color you can’t use the SET_LED command directly because the template will override the led next update cycle. You first need to disable the template:
# Set blank template to disable template
# Set solid blue color
SET_LED LED=rgb_light RED=0 GREEN=0 BLUE=1 WHITE=0
Thanks for the information, I will try out templates.
I have implemented some python code changes to idle_timeout.py that facilitates the behaviour around the delayed_gcode macros and still transition the states correctly by applying optionally switching the mode of behaviour using a new key in the printer config.
[idle_timeout]
    IDLE_TIMEOUT
timeout: 120
verbose_debug: True
robust_delayed_gcode: True
Is this a useful and desired expansion to add to idle_timeout behaviour?
I have cleaned the code and submitted a pull request.
