For some reason I want to cancel USB cable which from klipper host to Micro-control, then packaging klipper’s output data and copy to U disk, plug U disk to Micro-control(like gcode printing) unpackage and printing.
If it possible to redefine the serial communication API? any suggession? thanks.
A direct and permanent connection between the host and the MCU is required.
If you do not want to use an USB connection, the alternative is a direct serial connection via RX / TX pins.
Hi Sineos,
Thanks for your reply.
Because of the usage scenario, I urgently need to brake this rules(A direct and permanent connection with cable).
Any suggession for reprogram the serial API?
Thanks for your time.
