Inconsistent E-Steps
Printer Model: Voron 2.4 R2
Host / SBC Raspberry PI 4
Following the Ellis Tuning Guide, I get inconsistent measurements doing the E-Steps. They were;
14.16
14.14
14.51
14.93
14.01
So I used an average which was 14.35. Is this kind of variation normal and is using an average the best strategy?
Thanks!
klippy (4).zip (771.4 KB)
No idea from anyone?
What are you referring to with the numbers you are showing above?
Generally speaking, a well working extruder has a very high precision and except for the inherent measurement error the resulting extrusion distances should be quite close together.
The numbers in the previous posts are the differences between requested extrusion and actual extrusion. Doesn’t seem like there should be this much variation.
Have you checked the mechanics for no slack?
I suppose I’ll need to. This is a Stealthburner with CW2.
