I’m trying to upgrade to a Tronxy Black inductive sensor. Part integration successful, feeding it the required 12V and the sensor is able to halt the Z axis once in proximity. However… no settings I’ve found thus far around probing (probe speed, sample retraction distance, lift speed, [de]activate_gcode), Z retraction distance/speed have been able to fix the fact that the printer won’t move out of trigger range for the sensor after homing. Am I missing something?
@EddyMI3D thanks for the reply, but that setting does not seem to be applicable to the post home lift, I’ve increase from default to 10 and then 20 and they distance at which we retract after home is the same. Speed of retraction post home would probably be helpful here too… Haven’t found the appropriate setting… Still looking, feedback suggestions appreciated.
thanks for the reply… I tried that and a few variations (increased Z retract distance and speed [F1000], still no dice). what aggressive (should for sure resolve the problem) but safe (within safe Z acceleration for this dual Z machine) should I try next?
thanks for the reply. the triggered/open status is changing as expected. the issue is that I can’t seem to get the head to retract far/fast enough from the bed post home. @Arakon’s idea was a solid lead I think but still not getting the desired result.
@Sineos you got any other leads for me? I feel like I’ve seen a ton of folks with these on their rigs. I’m able to reproduce this on my Ender 5 plus and an Ender 3.
