Difficulties with Z probe "No trigger on z after full movement"
Printer Model: Tronxy X5SA pro
MCU / Printerboard: MKS Monster 8 V 2 + MKS PI V1.1
klippy.zip (118.1 KB)
Trying to home Z but I keep getting the error “No trigger on z after full movement”.
Ideas?
Tronxy stock blue induction sensor. All Klipper checks done successfully.
What kind of printer bed surface do you have?
Are you sure it can trigger the sensor?
It’s the stock bed from Tronxy. Yes it triggers, if I put the bed close to the sensor, 2-3 mm, the homing process works ok. If the bed is far than this, it gives me the error.
Another thing, after homing like I have mentioned above, I can get the bed down just a few mm using the GUI, after this, it will give me another error saying: “Move out of range: 0.000 0.000 -24.000 [0.000]”
I got it, my Z motors were inverted. I was following this article for x,y and z directions but my printer is a corexy, so the z+ should move downwards and not upwards as stated here. Another issue tackled, let me move to the next one.
