SV08 Mainlined, error on Z home, "No trigger on stepper z after full movement"
Sovol SV08. Stock hardware. Have not made any physical alterations to base unit, until I tried to switch to mainline klipper.
klippy.log (1.1 MB)
Installed mainline on my SV08, per rappetor howto on GitHub. Process appeared to go as expected. Only went through step 6 so far, I did not flash the MCUs with Katapult. Was going to do some printing first, and do the Katapult thing later. Can’t really see this being the issue, but perhaps that’s where I’ve gone wrong.
When I attempt to home the Z axis, the print head dives into bed and z step motors try and dig their way through. If you let it time out, you get the error:
I’ve searched that error without finding anything that really helped me. I’ve compared my original printer.config and the new one, along with options/probe/stock.config, I don’t really see any real differences.
Thanks for any assistance you can provide.
This is unrelated.
Your pressure-sensitive probe seems not to be reacting.
  • Unfortunately, this is an unknown Klipper modification, so we mostly cannot comment
  • Check all wiring
  • Test the functionality without endangering your bed or head:
    • Move gantry 90% up
    • Initiate z-homing
    • Manually exert pressure on the load-cell (bed? head? - I do not know the printer’s details)
    • If it does not stop, execute emergency shutdown
Thanks for your response. So… I’ve got a working printer, upgrade software, and now I’ve got a hardware problem? What are the chances?
Apparently, they’re not zero.
I swapped out the eMMC card, returned to original. Same problem. A bit of digging under the print head cover turned up a loose connector to the print head PCB.
Presto. Swapped the eMMC card again, printer correctly homes the Z axis.
Currently printing my 1st benchy on mainline Klipper.
Sorry for the trouble, thanks for assisting me, and for working with this excellent open source project!
