Changed probe, now "No trigger on stepper_z after full movement"
Printer Model:
MCU / Printerboard:
Voron V0 TriZero (triple belted Z)
SKR2 mainboard.
Raspi4 SOC.
config-20251005-213829.zip (8.5 KB)
I was running Tap/Boop as a bed probe, and recently converted the toolhead with an E3D PZ Probe. Now, when I try a G28 Z command as part of Homing Override, I get an error “No trigger on stepper_z after full movement” after the bed moves up about 5-10mm. I have changed very little except the [Probe] section of the printer.cfg, and messed about with E3D’s recommendation of lower stepper_z current while homing. I am totally at a loss. Any advice would be appreciated.
klippy(13).log (8.7 MB)
I spent some time changing and trying the presets on the PZ probe board, and the problem ceased when using setting 4, 5 or 6
Have you already checked the E3D troubleshooting infos? PZ Probe Standalone – E3D
Hi @Rainforetnomad ,
If you run a QUERY_PROBE command, what does it output?
If you press on the nozzle and run the command again, what does it output?
Is your problem solved? If it is please mark it solved.
Yes I have read the full page you linked already, my problem isnt described in the troubleshooting section.
The probe triggers when properly, is open on query_probe and triggers when tapped or touched. Have played with the various presets and noticed a difference in sensitivity.
Its not fully solved, as the behaviour changed as well. My quick update was somewhat premature. Id still be curious to know why the error occurs at a higher probe sensitivity, as I would expect “probe triggered prior to movement” or simply an early trigger before actual contact with the bed. On preset 4, the bed no longer lowers first before moving up.
I think I may understand what im seeing when I try to home Z. At first, the bed would move down a bit, and them begin to home towards the nozzle, after which point it would throw the error. Then after I changed the setting to 4 on the board, the bed would home towards the nozzle without moving down first. My belief is that at first, the board would see a false trigger before moving, and then begin a second homing whereupon it would move down 3mm then up about 10mm and not seeing a trigger this time, throw the error I was seeing. After changiing the board preset from 0 to 4, i introduced filtering and decreased sensitivity and then the board wouldnt get a false trigger, and so would home properly.
Does this make sense to anyone?
I have found some corroborating posts on discord, and on youtube about the “spurious” triggering of the probe, and I think I’m on the right track. There will be alot of trial and error getting this thing going. I’ll close this thread as I dont think klipper is doing anything wrong here, It’s just not obvious what is happening at first.
