Internal error during connect: list index out of range
Printer Model: VZ Bot
MCU / Printerboard: Octopus Pro F429 and Octopus F446
klippy.log (22.5 KB)
I`ve tested two Pi´s, two Octopus and two EBBs. I installed with Kiauh, RPi Imager and Balena Etcher. The Image downloads with RPI Imager, J Downloader and Chrome. Two releases tested and several SD´s , SSD and USB Stick
nothing change
Unhandled exception during connect
File “/home/pi/klipper/klippy/klippy.py”, line 180, in _connect
cb()
File “/home/pi/klipper/klippy/extras/bed_mesh.py”, line 131, in handle_connect
self.bmc.print_generated_points(logging.info)
File “/home/pi/klipper/klippy/extras/bed_mesh.py”, line 405, in print_generated_points
% (rri, self.points[rri][0], self.points[rri][1]))
IndexError: list index out of range
Thanks for help
Post your firmware settings, please.
fw
can
and your printer.cfg file, please. This looks like an error in the printer.cfg
ebb.cfg (1.6 KB)
fan.cfg (667 Bytes)
printer.cfg (4.7 KB)
You have relative_reference_index: 40 which is higher than your probe point count, hence the error.
If you don’t need relative_reference_index, then try to remove it.
thanks, that was the error
