"Internal error on command: "Z_TILT_ADJUST""
Printer Model: Voron Trident 350 bed
MCU / Printerboard: Bigtreetech Octopus pro v1.1
Host / SBC Raspberry Pi v4
klippy.log klippy_logs.rar
Describe your issue: When upgrading from klipper v0.13.0-152 to v0.13.0-504 and implementing a Z_TILT_ADJUST the printer (Voron Trident 350) errors out with message - Internal error on command:“Z_TILT_ADJUST”. The printer shuts down and has to be reset (firmware reset).
Have tested various versions of Klipper from v0.13.0-152 to v0.13.0-475 (I use kiauh) and these versions all work normally. Things start failing with “Z_TILT_ADJUST” from v0.13.0-476 onwards.
When implementing Z_TILT_ADJUST with v0.13.0-476 the toolhead moves to the first probing position and the bed begins to move up and printer shuts down.
When implementing Z_TILT_ADJUST with v0.13.0-504 the toolhead does not move and the printer shuts down instantly.
The Trident has RPi-4, Bigtreetech Octopus pro v1.1, BTT EBB SB2240 Can v1.0 for Stealthburner, BTT U2C v2.1, Cartographer v3.0.
Thanks.
klippy_logs.zip (187.1 KB)
You have a cartographer.
