Internal error on command:"Z_TILT_ADJUST"
Printer Model: FlyingBear Reborn 2
MCU / Printerboard: BTT U2C, MKS RN v3.2, EBB36, Cartographer V3
Host / SBC Orange pi 3b
Greetings, the problem is probably not new, but it has not been solved, maybe you can help solve it, searching the Internet has not yielded results. When you turn on the table alignment button for the Z and Z1 motors, the 3d printer turns off when turned on, an error appears in the console Internal error on command: “Z_TILT_ADJUST”. Since I’m just studying 3D printing and I’m not good at programming, I can’t fix this problem, so please tell me what to do in this situation. Thanks
klippy (26).log (841.1 KB)
Hello @RiDDiK !
You may have a look on this: PSA: Bed Mesh, QGL, or Cartographer Issues?
Thanks, it’s currently running on the latest version of klipper, the mapper has been updated to version 1.4.0, and everything is working
