Invalid root (Goode)
I just did a fresh install on my Voron V0 with Kiauh with SKR mini 3 V2.
klippy (7).log (92.2 KB)
Looks like the Linux process is not or not properly installed. Follow RPi microcontroller - Klipper documentation
Thanks for the help, followed the instructions now I’m getting this and fan runs continuously.
See
https://www.klipper3d.org/RPi_microcontroller.html#optional-enabling-spi
That got it, thanks I really appreciate the help.
well everything was working fine then i had a power failure in the middle of a print and now its not working. Any idea what happened? I flashed firmware again no change.
I did some research and tried a few things. I replaced the skr mini E3 V2 with a new board and also tried a new stepper motor, still getting the same error. If I home any of the axis I get same message for that axis.
Found the problem fuse blew on 24v power supply :grin:
