hello guy, newbie is here please after I flash and setup everything with klipper and I tried to print calibration cube but no matter how many time I tried I always get this Invalid speed in 'G0 F0 X101.5 Y117.79 Z0.4
no matter what 3d object i tried to print i always having this error
here is my printer config file
##################Creality Ender 3 S1 Klipper Config - 3DPrintBeginner###################
######Full guide: https://3dprintbeginner.com/how-to-install-klipper-on-ender-3-s1/######
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
rotation_distance: 40
endstop_pin: !PA5
position_endstop: 0
position_max: 258
homing_speed: 50
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
endstop_pin: !PA6
position_endstop: 0
position_max: 230
homing_speed: 50
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
rotation_distance: 8
position_max: 270
position_min: -5
max_extrude_only_distance: 100.0
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
rotation_distance: 7.6190
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
pid_Kp: 22.865
pid_Ki: 1.292
pid_Kd: 101.178
min_temp: 0
max_temp: 250
pressure_advance = 0.12
[filament_switch_sensor RunoutSensor]
pause_on_runout: False
runout_gcode: PAUSE
insert_gcode: RESUME
switch_pin: !PC15
[heater_bed]
heater_pin: PA7
sensor_pin: PC4
control: pid
pid_Kp: 69.139
pid_Ki: 1.273
pid_Kd: 938.565
min_temp: 0
max_temp: 130
[heater_fan hotend_fan]
pin: PC0
heater: extruder
heater_temp: 50.0
[fan]
pin: PA0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 500
max_accel: 3000
max_accel_to_decel: 3000
max_z_velocity: 5
square_corner_velocity: 5.0
max_z_accel: 100
[bltouch]
sensor_pin: ^PC14
control_pin: PC13
x_offset: -32
y_offset: -41
#z_offset: 2.80
speed:10
samples:1
samples_result:average
probe_with_touch_mode: true
stow_on_each_sample: false
[safe_z_home]
home_xy_position: 154,154
speed: 100
z_hop: 10
z_hop_speed: 5
[bed_mesh]
speed: 100
mesh_min: 10, 10
mesh_max: 225, 189
algorithm: bicubic
probe_count: 5,5
[temperature_sensor Board_MCU]
sensor_type: temperature_mcu
min_temp: 0
max_temp: 100
[temperature_sensor Raspberry_Pi]
sensor_type: temperature_host
min_temp: 0
max_temp: 100
[virtual_sdcard]
path: ~/gcode_files
[gcode_macro START_PRINT]
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(205)|float %}
# Start bed heating
M140 S{BED_TEMP}
# Use absolute coordinates
G90
# Reset the G-Code Z offset (adjust Z offset if needed)
SET_GCODE_OFFSET Z=0.0
# Home the printer
G28
G1 Z5 F3000
G1 Z0.15 F300
# Wait for bed to reach temperature
M190 S{BED_TEMP}
# Set and wait for nozzle to reach temperature
M109 S{EXTRUDER_TEMP}
[gcode_macro END_PRINT]
M140 S0
M104 S0
M106 S0
G91
G1 X-2 Y-2 E-3 F300
# Raise nozzle by 10mm
G1 Z10 F3000
G90
# Disable steppers
M84
[display_status]
[pause_resume]
[gcode_macro PAUSE]
description: Pause the actual running print
rename_existing: PAUSE_BASE
# change this if you need more or less extrusion
variable_extrude: 1.0
##### read E from pause macro #####
{% set E = printer["gcode_macro PAUSE"].extrude|float %}
##### set park positon for x and y #####
# default is your max posion from your printer.cfg
{% set x_park = printer.toolhead.axis_maximum.x|float - 5.0 %}
{% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
##### calculate save lift position #####
{% set max_z = printer.toolhead.axis_maximum.z|float %}
{% set act_z = printer.toolhead.position.z|float %}
{% if act_z < (max_z - 2.0) %}
{% set z_safe = 2.0 %}
{% else %}
{% set z_safe = max_z - act_z %}
##### end of definitions #####
PAUSE_BASE
G91
{% if printer.extruder.can_extrude|lower == 'true' %}
G1 E-{E} F2100
{% else %}
{action_respond_info("Extruder not hot enough")}
{% if "xyz" in printer.toolhead.homed_axes %}
G1 Z{z_safe} F900
G90
G1 X{x_park} Y{y_park} F6000
{% else %}
{action_respond_info("Printer not homed")}
[gcode_macro RESUME]
description: Resume the actual running print
rename_existing: RESUME_BASE
#### get VELOCITY parameter if specified ####
{% if 'VELOCITY' in params|upper %}
{% set get_params = ('VELOCITY=' + params.VELOCITY) %}
{%else %}
{% set get_params = "" %}
G91
G1 E{E} F2100
{% else %}
RESUME_BASE {get_params}
[gcode_macro CANCEL_PRINT]
description: Cancel the actual running print
rename_existing: CANCEL_PRINT_BASE
TURN_OFF_HEATERS
CANCEL_PRINT_BASE
#*# [bltouch]
#*# z_offset = 2.300
thanks for your help in advance
