Is there a 3 Stepper Equivalent to "quad_gantry_level"
I’m sure it’s probably somewhere, but I can’t find it. I’ve gone through the docs and looking on line.
I want to set up my printer with three stepper motors at the front two corners and the rear middle with autoleveling but I don’t see anything in the documents that performs this.
“quad_gantry_level” works for four (and I presume its for the Voron 2.4, but I can’t find anything for three.
Thanx for any pointers to the Klipper code for doing this!
https://www.klipper3d.org/Config_Reference.html#z_tilt
Thank you but I’m still not 100% sure how this works.
I did find this: Z_tilt Correction help configuration? · Issue #2857 · Klipper3d/klipper · GitHub which has the problem of the 3 Z Axis motors wired differently than specified in printer.cfg.
So, if I understand things correctly, I first specify my Z, Z1 and Z2 stepper motors and my Z axis probe (which will be a BL touch) in printer.cfg.
Next, I specify z_tilt (Configuration reference - Klipper documentation) with the necessary points and other parameters.
To manually level the system, I will execute the command “Z_TILT_ADJUST” which will use the information I put in printer.cfg.
Now, when I (or the printer itself) issue a “Home” Command (say G28), will the system be leveled as part of the command?
Thanx!
It can be, but you would need to include z_tilt_adjust in a homing_override. It’s a fully automated process once you configure it. It will probe your specified points, adjust the motors, and stop once the highest and lowest points are within the tolerance you specify.
Thanx - I’m a few days away from trying it out and I’ll update this thread then.
The Rat Rig uses this kinematics: V-Core 3 - All 3D Printer Kits - 3D Printing - 3D Printing & CNC
Maybe you can get some infos from there… They use Klipper as well, so there should be existing maths for it.
Thanx - I saw the V-Core 3 but I can’t find any Klipper files other than a somewhat vague reference to it here:
Can you point me to anything more substantial?
Look here for a basic introduction of the Rat Rig: What is RatOS? | RatOS
I would download and install the image and then look into their Klipper printer config (printer.cfg) there should be the answer.
Else you send a mail to miklschmidt#2036 on the Rat Rig Unofficial Discord
or take a look in the repository here:
maybe you have to search the basic config file a little, the naming seems to be a little different like in klipper…
Thank you - that’s what I couldn’t find before.
