Printer Model: Voron 2.4r2 with Tap probe.
MCU / Printerboard: Octopus pro with EBB36 canbus board. klippy.log
Fill out above information and in all cases attach yourklippy.logfile. Pasting yourprinter.cfgis not needed When pasting code or config snippetsusethe code tags</>in the menu above
I get this error when I do QUAD_GANTRY_LEVEL and the printer just probed 4 spots and trying to start adjust 4 z steppers.
Internal error on command:“QUAD_GANTRY_LEVEL” Once the underlying issue is corrected, use the “FIRMWARE_RESTART” command to reset the firmware, reload the config, and restart the host software. Printer is shutdown.
It was OK before I upgraded to Tap probe. Previously I have used euclid probe. Attached klippy.log and moonraker.log. Do anybody have any idea why is causing the problem? Thanks for your help.
What about a clean config, IE start from a generic Voron V2.4 config and add only the minimum needed to get the machine going with your Canbus Tool head?
No sub files just what is needed
I found the actual reason. In the python code at 43rd line of klippy/extras/z_tilt.py:
# Move each z stepper (sorted from lowest to highest) until they match
positions = [(-a, s) for a, s in zip(adjustments, self.z_steppers)]
positions.sort()
if the adjustment values, i.e., -a, in the tuple are coincidently the same, the second element of the tuple, i.e., s which is MCU_stepper object is used for sorting. That is causing the error. So, the code should change to
positions.sort(key=lambda k: k[0])
Also I found a mistake in my config after changing from euclid to tap probe. I put 4 x,y tuples in gantry_corners in [quad_gantry_level] section. That might have been a root cause.
