QUAD_GANTRY_LEVEL internal error
Printer Model: Siboor kit Voron 2.4
MCU / Printerboard: BTT Octopus + sb2209 CAN
Host / SBC BTT Pi
klippy (2).log (4.2 MB)
…Hello I am having an issue where as soon as the printer goes to QGL it crashes with the orange screen stating internal error. I saw the locked post about this but after updating everything it still isn’t working. I had this problem before, and my solution was to roll klipper back 100 or so versions, which was working just great however it turned out I needed to upgrade to get my ERCF to work.
Please help this is driving me crazy…
You never mentioned the use of cartographer-klipper
Did you read the README.md here cartographer-klipper/firmware/v3 at master · Cartographer3D/cartographer-klipper · GitHub?
I guess your installation of Cartographer is causing your problem.
Sorry, I can’t help you. I never used Cartographer.
You might get help on their Discord https://docs.cartographer3d.com/
Good luck, hcwt14
PS: Interesting price for an eddy current sensor :sunglasses:
I fully support you! I spent about 12 hours solving the problem on my new Voron 2.4 and still haven’t solved it. Apparently we need to wait for some special update. If I solve this problem I will definitely let you know. (rolling back to 300 commits might have helped me, but I’m too lazy to flash the firmware and restore settings)
I think the above post is correct in the cartographer documentation it states a version of klipper after which the cartographer firmware needs to be updated
All versions all programm and firmware latest.
There is simply no newer…
bro I received official answer, QGL working on Klipper version (V0.12.0-114)
new version is not working…
I had a similiar issue on my voron. I now have the indication, it might have been the led_effects. I see in your log, you are using these as well.
See:
Could you try disabeling the led_effects to test if your issues still persists afterwards.
