Issue with sending manual G1 moves back to back
Printer Model: Anycubic Kobra Go
MCU / Printerboard: Trigorilla
klippy (1).zip (727.6 KB)
Recently I was trying to perform a few tests and wanted to send multiple move commands to the printer via copy-paste. I could send as many Z commands as I wanted but when I added X commands there was an error. After the first X move, I received an out of bounds error and it didn’t matter what locations I told it to go to. The only workaround I found was to send a G28 X before the next X move each time.
I don’t have the block I pasted but it was basically this and variations of it.
G1 Z50 F4000
G1 X225 F12000
G1 X0 F12000
G1 Z300 F4000
G1 X50 F12000
G1 X0 F12000
G1 X225 F12000
G28
What I ended up doing was adding ‘G28 X’ before each Z move. It’s like it forgot its position between moves. I say that because at one point I told it X50 then X20 and it moved an additional 20 over 50.
Thank You
I found these error messages:
Move out of range: 115.000 115.000 -10.000 [0.000]   # Z too low
Move out of range: 225.000 115.000 525.013 [0.000]   # Z too lhigh
Move out of range: 225.000 115.000 425.013 [0.000]   # Z too high
Move out of range: 335.000 115.000 180.057 [0.000]   # X too high
Move out of range: 263.000 -9.000 180.012 [0.000]    # X too high
Move out of range: 413.000 -9.000 180.012 [0.000]    # X too high
Move out of range: 237.000 -9.000 179.950 [0.000]    # X too high
And so on.
Have you turned on relative positioning G91 before?
Do you mean at any point during the life of my setup? Or did I issue the command manually? In startup GCode its possible.
The odd part is that I just tested again, check the log I attached, and I ran the Z up and down, then to the top and back, and it’s taking the command as absolute, as I assume it should. I’m not sure why it thinks I wanted to move Z to 425 and 525, that isn’t how the command read and it would only happen after an X move, as you can see in the new log. The issue didn’t occur when only moving Z.
klippy (2).zip (731.8 KB)
I had another look on the log and the basic modules.
3rd party macros are in responsibility of the authors.
I can’t tell if there is something wrong.
But I found a G91 in [gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL]
I noticed that the homing is way too fast. This is a precision act and should be done slow.
You may stay with the default (5 and 2.5, maybe 10 and 5), but 100 and 20 is too fast.
Also, in [stepper_y] you have a pull-up resistor configured for the endstop_pin, in [stepper_x] not.
I’m not sure on the pullups, I used the config in the example for the Kobra Go and this is an Anycubic board we’re talking about… They do some weird crap to save a $, actually pennies. i.e. UART Mux to the knock off 2208’s to save 3 pins.
Hmm now that you say that I wonder if that’s the “default” of the 4 drivers, because I was thinking one of them could be used on the UART line without selecting it. Anyway, different topic all together relating to the board, driver, firmware and reverse engineering.
Circling back to the first thing you said though, I don’t believe I have any 3rd party Macros. Could that of been from S3D slicer? When I was troubleshooting some issues I changed between profiles, and some had GCode from Marlin in them that I didn’t notice at first.
The homing speeds are reduced substantially after the bump. The quick speed is just to get there then it slows to a crawl (2 on the Z) to do the actual probe and 20 on the X Y to re-hit the switches. My default speeds are a little slower than what’s currently set. I was testing a few things out and it was easier with a little quicker speeds.
I dropped them to 80/20 X,Y and 25/2 on Z
I can re-test
I’m not sure how or why the homing speeds would affect that but I lowered them, then ran the following groups of commands and no error???
G28
G1 Z100 F3800
G1 X50 F8000
G1 X200 F8000
G1 X0 F8000
G1 Z50 F3800
G1 Z250 F3800
G1 X220 F8000
G1 Z0 F3800
G1 Z200 F3800
G28
G28
G1 Z100 F4000
G1 X50 F12000
G1 X200 F12000
G1 X0 F12000
G1 Z50 F4000
G1 Z250 F4000
G1 X220 F8000
G1 Z0 F3800
G1 Z200 F3800
G28
Edit: On my end I can move on, but this might warrant some further investigation if its a manifestation of an underlying issue that may affect others in a similar fashion.
Thank You for taking the time to look over my configs and troubleshoot through this with me, I sincerely appreciate your time.
klippy (3).zip (33.0 KB)
