I am trying to install Klipper on my Ender 3 w/ BTT SKR Mini E3 1.2 but running in to a few issues.
I am getting the message “ls: cannot access ‘/dev/serial/by-id/*’: No such file or directory” when I am trying to determine the serial port. I’ve seen a few post with a similar problem with newer klipper installs, so I used an older version of Klipper for the sole purpose of finding out what the serial is. That’s where I am obtaining the value used in printer.cfg under the MCU section.
My log file shows a few issues, such as not being able to being able to open the serial port, or formatting/syntax issues with my printer.cfg file because I tried using an old working version I had saved, resulting in an error “Error: Option ‘microsteps’ in section ‘stepper_x’ must be specified”. In those instances, though, it does seems like I am making a connection with the serial, so I don’t understand why I am not able to connect at other times. Fixing the various syntax/format issues seems to result in an error connecting to the board.
Klippy.log can be found here https://pastebin.com/raw/rqqnM7W0
