Calling all JINJA experts!
For the record - I am not a Jinja syntax fan. Like, at all ![]()
I have been able to do some fairly complex gcode macros with it to adapt to variables that CURA spits out, but for some reason, I cannot get it to interpret my string variables.
Goal:
In CURA 4.13+, you can get access to material parameters. I found this extremely useful to dynamically control things, like pressure advance parameters based on the material in use in the active extruder. I have a START_PRINT macro that uses variables set from the CRUA start gcode block. My T0 and T1 gcode macros read some of the START_PRINT variables and use them directly, or to set other gcode macro variables (like pressure advance). See snippets below:
CURA Start Gcode Block:
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_type_0 VALUE='"{material_type}"'
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_type_1 VALUE='"{material_type, 1}"'
T0/T1 Custom GCODE:
#Change toolhead T0
[gcode_macro T0]
ACTIVATE_EXTRUDER EXTRUDER=extruder
M109 S{(printer["gcode_macro START_PRINT"].material_print_temperature_initial_0)} ;# wait for print temp
POSITION_E0
SET_GCODE_VARIABLE MACRO=SET_MATERIAL_PRESSURE_ADVANCE VARIABLE=material_type VALUE='"{(printer["gcode_macro START_PRINT"].material_type_0)}"'
And, this is the gcode macro that decoded the material type to change the pressure advance setting:
[gcode_macro SET_MATERIAL_PRESSURE_ADVANCE]
variable_material_type: '"PLA"'
{% if material_type == "PLA" %}
;M117 PLA
SET_PRESSURE_ADVANCE ADVANCE=0.055
{% elif material_type == "ABS" %}
;M117 ABS
SET_PRESSURE_ADVANCE ADVANCE=0.035
{% else %}
;M117 ???
SET_PRESSURE_ADVANCE ADVANCE=0.000
{% endif%}
Below is a snippet of what the gcode file looks like from CURA from a slice using PLA and PVA from the Start Gcode block:
;Generated with Cura_SteamEngine 4.13.1
T0
M82 ;absolute extrusion mode
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_type_0 VALUE='"PLA"'
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_type_1 VALUE='"PVA"'
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=extruders_enabled_count VALUE=2
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_standby_temperature_0 VALUE=195.0
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_standby_temperature_1 VALUE=175
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_bed_temperature_layer_0 VALUE=60.0
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_print_temperature_layer_0_0 VALUE=210.0
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_print_temperature_layer_0_1 VALUE=230.0
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_print_temperature_initial_0 VALUE=200.0
SET_GCODE_VARIABLE MACRO=START_PRINT VARIABLE=material_print_temperature_initial_1 VALUE=220.0
; Execute START_PRINT GCODE defined in Klipper config file
START_PRINT
G92 E0
;START_EXTRUDER_1
G92 E0
G1 F2400 E-3
;LAYER_COUNT:297
;LAYER:0
M107
M104 T1 S175
G0 F3600 X105.527 Y123.667 Z0.3
;TYPE:SKIRT
G1 F2400 E0
G1 F1800 X106.314 Y123.055 E0.04974
G1 X106.448 Y122.956 E0.05805
G1 X107.267 Y122.389 E0.10775
I keep getting errors when running the
SET_GCODE_VARIABLE MACRO=SET_MATERIAL_PRESSURE_ADVANCE VARIABLE=material_type VALUE="{(printer["gcode_macro START_PRINT"].material_type_0)}"
command saying that the result is not a literal. I have tried all kinds of combinations with single and double quotes and get errors ranging from “internal errors from SET_GCODE_VARIABLE” to “Unable to parse ‘PLA’ as a literal”.
I could sure use some guidance on strings, and maybe a good reference to this languag!
I’d appreciate any help. Thanks!
