Klipper crashing when attempting calibrate for bed mesh
Printer Model: Homebrew cartesian
MCU / Printerboard: skr v1.4 turbo + pi 3b v1.2
I can home, print all as normal but as soon as I home and attempt to calibrate my bed mesh I get an error. i am using a bltouch clone, burt it works fine for homing and I can do the tests on it which it passes.
i am getting the following error:
MCU ‘mcu’ shutdown: Rescheduled timer in the past
This generally occurs when the micro-controller has been
requested to step at a rate higher than it is capable of
obtaining.
Printer is shutdown
I am new to klipper but had this machine running perfect under marlin. Finding klipper easy to use and would preer to keep on this solution if at a ll possible
klippy.log (6.2 MB)
Speed in Klipper are given in mm/s. You request a probing speed of 1500 mm/s. Default is 5 mm/s
Thanks @Sineos - that has solved the problem
