Timer too close when homing
Printer Model: ender 3 pro
MCU / Printerboard:4.2.2
klippy (14).log (601.1 KB)
Describe your issue: i can heat bed and nozzle but when it tries to home i get this error msg…
MCU ‘mcu’ shutdown: Timer too close
This often indicates the host computer is overloaded. Check
for other processes consuming excessive CPU time, high swap
usage, disk errors, overheating, unstable voltage, or
similar system problems on the host computer.
Printer is shutdown
Take care that the printer does not home too fast.
The values of 50 for X and Y and 25 for Z are way too high.
Stick to the default values of Klipper (5.0 mm/s)
Also take care that the USB cable is good quality (ferrite beads etc) and as short as possible and away from EMI sources like the Ender LCD.
will try slower movements.
i do have two other identical printers running without errors.
slower movements = no change, still throwing timer error
Likely as the error message indicates: Your host is overloaded. Given that it is a 4 core processor, e.g. a RPI 3, then the spike at ~420% indicates that all cores are (over)loaded.
Check other processes, webcam etc.
i dont have any other processes that i know of. no camera.
Klipper alone runs on a RPi Zero, which has the computing power of a wooden stick. Apparently something is driving your CPU load, leading to the shutdown.
i dont know how to find the usage.
i found this but dont know what it is or how its malfunctioning…
using th ps- aux command in putty
its using 35% of the cpu
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME
pi 343 35.3 6.6 282672 24888 ? Rsl 15:45 97:16
COMMAND
/home/pi/moonraker-env/bin/python /home/pi/moonraker/moonraker/moonr
This is moonraker, the interface process between Klipper and the web-interfaces like fluidd or mainsail.
No idea, why it is using 35% of your CPU.
  • Post your moonraker.log
  • What do you use a host computer? RPi 3?
i switched out components and sd card with a known working printer and the pi or the cables must be the problem.
currently setting up a wireless pi3a to replace the bad pi3b.
can a pi be diagnosed or repaired?
Hi. Have you found the origin of your problem ?
I have 2 instance of Klipper 1 is okay with Sidewinder
The second LK4 Pro is having the mcu too close when homing the rest is okay set extrud temp set bed temp…
I tried the lk4 Pro alone without screen and pi cam and Sidewinder, it’s the same. I have an old Sd card of 32 Gb.
Here is my klippy.log.
klippy(2).log (4.2 MB)
Thanks in advance !
It seems your issue is a few lines up from the Timer too close error
Resetting prediction variance 647.423: freq=8000000 diff=428292 stddev=8000.000
See Klipper suddenly stopping early print on my Ender 6 which has been working for months - #2 by Sineos
My problem was the pi.
I replaced it and the problem went away.
Okay thank you both for your reply.
I managed to get all working without my pi-cam.
