Klipper does support BIGTREETECH SKR 2 MOTHERBOARD
I am new to Klipper so I don’t know more about Klipper
more detail of SKR v2 board: https://www.bigtree-tech.com/products/bigtreetech-skr-2.html
Yes, it does.
The only thing you have to add is:
# "killer" feature :-)
[output_pin motor_power]
pin: PC13
value: 1
in your printer.cfg (this pin is for “anti-reverse stepper driver protection”, afaik used only in Marlin. First release of this board had issue which causes to kill your correctly installed TMC drivers)
As Kmarty mentioned Klipper does support the SKR 2 and there is a basic config file in the examples folder. I am using an SKR 2 with Klipper and everything seems to be working well. If you want I can post my printer.cfg file for you to start from.
Thanks for your help.
If you can share your SKR V2 board configuration file it will help me a lot.
Thanks again for your help.
It’s an officially supported board. If you install Klipper, it will include the generic config for this board.
printer (1).cfg (6.2 KB)
