Klipper lost communication with mcu with bigtreetech octopus v1.1
klipper ‘lost communication with mcu’ with bigtreetech octopus v1.1, every time error occurs in first 1 minute of printer startup. it works fine with my old setup with ramps 1.4.
klippy.log (5.4 MB)
Please attach your klippy.log
klippy.log (5.4 MB)
and
This error occurs every time when I home z axis.
klippy (1).log (5.4 MB)
Please verify the settings you used in menuconfig for flashing. It appears you updated Klipper and I’m wondering if you chose the wrong crystal speed when flashing the board.
I selected it by recommended value 12Mh crystal clock speed from klipper configuration references for bigtreetech octopus board.
The only issue that jumps out is all the SET_LED commands that are causing errors because you don’t have a neopixel defined.
