rafik
April 22, 2021, 1:07pm
1
Hi Community !
I am trying to run a second MCU on the host using an RPI 3B and I have followed all documentation I could find or been pointed at but no joy so far.
I have installed OctoPI got Klipper working and connecting to my printer but tryin to launch out/klipper.elf aka /usr/local/bin/klipper_mcu is segfaulting regardles of being launched via the /etc/init.d/klipper_mcu or manually result is segfault with exit code 139.
Enabling core dump does not generate any core dump so I tried to run in valgrind and got:
valgrind ./out/klipper.elf
valgrind: mmap(0x0, 40960) failed in UME with error 22 (Invalid argument).
valgrind: this can be caused by executables with very large text, data or bss segments.
I did enable GPIO SPI in raspi-config, added the executable bit on the binary added pi user to tty group, used make MCU=2 and all i could find as part of the github issues in vain.
Could you please help ?
Thanks in advance,
Rafik
Sineos
April 23, 2021, 9:40am
2
This is highly unusual.
My config:
RPi 3B
Ubuntu 20.04.2 LTS
Klipper git v0.9.1-442-gdfccc872
Simple make menuconfig → Linux → make → make flash
What OS do you use?
Console Output:
ubuntu@ubuntu ~/klipper $ make menuconfig
Using default symbol values (no '/home/ubuntu/klipper/.config')
Configuration saved to '/home/ubuntu/klipper/.config'
Creating symbolic link out/board
Loaded configuration '/home/ubuntu/klipper/.config'
Building out/autoconf.h
Compiling out/src/sched.o
Compiling out/src/command.o
Compiling out/src/basecmd.o
Compiling out/src/debugcmds.o
Compiling out/src/initial_pins.o
Compiling out/src/gpiocmds.o
Compiling out/src/stepper.o
Compiling out/src/endstop.o
Compiling out/src/adccmds.o
Compiling out/src/spicmds.o
Compiling out/src/thermocouple.o
Compiling out/src/i2ccmds.o
Compiling out/src/pwmcmds.o
Compiling out/src/lcd_st7920.o
Compiling out/src/lcd_hd44780.o
Compiling out/src/buttons.o
Compiling out/src/tmcuart.o
Compiling out/src/spi_software.o
Compiling out/src/neopixel.o
Compiling out/src/sensor_adxl345.o
Compiling out/src/pulse_counter.o
Compiling out/src/linux/main.o
Compiling out/src/linux/timer.o
Compiling out/src/linux/console.o
Compiling out/src/linux/watchdog.o
Compiling out/src/linux/pca9685.o
Compiling out/src/linux/spidev.o
Compiling out/src/linux/analog.o
Compiling out/src/linux/hard_pwm.o
src/linux/hard_pwm.c: In function ‘gpio_pwm_setup’:
src/linux/hard_pwm.c:69:5: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
69 | write(fd, scratch, strlen(scratch));
src/linux/hard_pwm.c: In function ‘gpio_pwm_write’:
src/linux/hard_pwm.c:105:9: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
105 | write(g.enable_fd, "0", 2);
src/linux/hard_pwm.c:111:5: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
111 | write(g.duty_fd, scratch, len + 1);
src/linux/hard_pwm.c:112:5: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
112 | write(g.enable_fd, "1", 2);
Compiling out/src/linux/i2c.o
Compiling out/src/linux/gpio.o
Compiling out/src/generic/crc16_ccitt.o
Compiling out/src/generic/alloc.o
Compiling out/src/linux/sensor_ds18b20.o
Building out/compile_time_request.o
Version: v0.9.1-442-gdfccc872
Linking out/klipper.elf
ubuntu@ubuntu ~/klipper $ make flash
Flashing
Installing mirco-controller code to /usr/local/bin/
Attempting host MCU restart...
