I’m trying to install Klipper on my LG V20 running LOS 18.1 (AOSP 11) and a 3.18 kernel compiled with the ch341 driver. I’ve seen multiple instances of people having installed Klipper on their Android device in a chrooted Linux: 1, 2. I’ve been trying to do that for the past few days, but with little success even though, on the exact same setup, Octoprint was running for over a month with little to no Issues. The main problem I’m facing is the printer not showing up in /dev/serial/ , It only shows up in /dev/ttyUSB[0-9] and /dev/bus/usb/001/00[^1] and when I point the serial: flag in printer.cfg to it I get errors in the klippy.log like ‘can’t open /dev/ttyUSB0’. I tried changing the permissions to 777, doesn’t work. I also tried installing Klipper in a VM on my main PC, it works and can communicate with the printer. My best guess is that I don’t have proper kernel serial driver support, that would make this question a bit off-topic, but I’ve asked on multiple places and still haven’t figured it out. TLDR; Printer doesn’t show up in /dev/serial on Android, how do I fix it so it does?
Fluidd error:
mcu 'mcu': Unable to connect
Error configuring printer
Important tail of klippy.log:
mcu 'mcu': Starting serial connect
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/bus/usb/001/002: [Errno 2] No such file or directory: '/dev/bus/usb/001/002'
webhooks client 488878322544: New connection
webhooks client 488878322544: Client info {'program': 'Moonraker', 'version': 'v0.7.1-376-g34f607c'}
…same with /dev/ttyUSB0.
Important output of lsusb:
Bus 001 Device 004: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x1a86 QinHeng Electronics
  idProduct          0x7523 CH340 serial converter
  bcdDevice            2.64
  iManufacturer           0
  iProduct                2 USB Serial
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0027
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower               98mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      1
      bInterfaceProtocol      2
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0020  1x 32 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval               1
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0000
  (Bus Powered)
Edit, forgot the output of dmesg, it recognizes the printer and attaches the ch341-uart converter to it (just search for ‘ch341’): http://sprunge.us/HfUEAe (too long of a message, and I’m getting an error when uploading a txt/zip)
I hope I’m not too off-topic and that anyone who has any ideas will chime in.
