Printer Model: Ender 3 V3 SE
MCU / Printerboard: stock
klippy (7).log (538.0 KB)
I’ve set up and installed Klipper by following the guide at Redirecting..., adjusting the steps to install on Ubuntu with WSL (Windows Subsystem for Linux), as I don’t have a raspbi I could use.
After flashing my Ender 3 V3 SE and accessing the web interface of both fluidd and mainsail failed to connect to the printer it seems:
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/<your-mcu-id>: [Errno 2] No such file or directory: '/dev/serial/by-id/<your-mcu-id>'
from the host, both ttyUSB0 and /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0exists and in my config file I have it correspondingly
#serial = /dev/serial/by-id/<usb-1a86_USB_Serial-if00-port0>
serial: /dev/ttyUSB0
I have tried them both, but the problem still persisted.
Thanks in advance for the help
