…hello, here is my problem I installed mosaic palette 2, everything works for the commands but when I do a print klipper stops as soon as there is the command 031 as in the topic here:
is there a solution?
Sorry, but with that few information its hardly not possible to even make an assumption. Not even the klippy.log (it seems the template is of no use).
What topic?
And the klippy.log?
sorry, the klippy was too big, I had to rework it, but here it is ![]()
klippy (3).log (2.2 MB)
Please do not “rework” a log. You can compress it to a zip-file (as it was described in the template you deleted in the first post).
ok , I just cut it and glued it back together, but I’ll know for next time, thanks.
sorry if the translation is not great, but I am French and I use translate
We would appreciate when you upload your code as preformatted text and not as a photo.
