Klipper Palette2s - Unhandled exception
Printer Model: CR10S
MCU / Printerboard: Stock
Host / SBC: Raspberry Pi 4
I have sliced a print using the the Mosaic Canvas3d.io slicer - as PrusaSlicer with p2pp will halt my palette when print begins (It will not procide filament when pulled from the buffer).
During the print (after ~1hour) an exception occurs and klipper occurs:
Sending current ping info O31 D46beead2
Unhandled exception during run
  File "/home/pi/klipper/klippy/klippy.py", line 217, in run
    self.reactor.run()
  File "/home/pi/klipper/klippy/reactor.py", line 292, in run
    g_next.switch()
  File "/home/pi/klipper/klippy/reactor.py", line 340, in _dispatch_loop
    timeout = self._check_timers(eventtime, busy)
  File "/home/pi/klipper/klippy/reactor.py", line 158, in _check_timers
    t.waketime = waketime = t.callback(eventtime)
  File "/home/pi/klipper/klippy/extras/palette2.py", line 578, in _run_Read
    self.p2cmd(text_line)
  File "/home/pi/klipper/klippy/extras/palette2.py", line 519, in p2cmd
    func(params)
  File "/home/pi/klipper/klippy/extras/palette2.py", line 382, in p2cmd_O34
    percent = float(params[1][1:])
ValueError: invalid literal for float(): 0.-1
Transition to shutdown state: Unhandled exception during run
klippy.log.shutdown02831.zip (4.8 MB)
Well, Looking at the palette2 code (and is obvious by your error), the python code tried to convert a .-1 to a floating point value.
I don’t know enough about the Palette2 to know why or how it gave a .-1 value as a return, as .-1 isn’t a number.
You might have some error lurking in your Palette2, but again, I don’t know enough about that to comment.
What I can do is…
palette2.zip (5.5 KB)
Drop that files into your ~/klipper/klippy/extras folder and replace the existing palette2.py.
I added a conversion check to make sure the value in the param is a legit float, if not it’ll make it a “NaN” as a default value.
Hopefully that more gracefully deals with it and doesn’t just die on you. I added right above that a new logging output to say when the an invalid parameter was fed into that p2cmd so maybe later we can see if it happens a lot.
Hi @TheFuzzyGiggler
Are you the maintainer of the palette2s module?
I am just a user of klipper and palette2s. I have followed the documentation and it has been working for a long time.
Lately (after updating klipper etc), I have experienced these crashes during print.
To me it looks like the palette2s module are not correctly parsing/handling the Omega code O31 response. To my understanding, this is a ping - correct?
I have had some issues with my palette2s, but it turned out some compatibility problems with p2pp and prusaslicer. It would somehow overload/crash the palette during filament loading.
Switching back to canvas3d.io fixed the problem - for now at least.
I will test your fix and see if it helps.
I am not, The signature on the palette2 module is:
Clifford Roche clifford.roche@gmail.com
He wrote it in 2021, not sure if he’s still active or actively maintains it.
As for my fix, I simply tried to handle the error more gracefully than what happened above. I did a cursory Google on how the palette2 works but it has a lot going on behind the scenes and I don’t have one to test with so that killed my chances of trying to go any further.
