Printer Model: Ratrig Vcore31
MCU / Printerboard: Octopus Pro+EBB42
Host / SBC rPi 4
Not an issue…
From time to time the printing in progress stops, due to some other error…
I get a message in the console, explaining the error, but most of the time I don’t know how to identify it…
I know that klippy.log can help me, but the truth is that I don’t understand its structure very well.
I would like to obtain more information on how to understand the log and console errors, to be able to identify the problems that arise in a semi-autonomous way…
It is clear that there will be many of them that I do not know, and I will need your help… But, I hope, there are others that I can.
Where can I find information about the Klipper LOG? (What is its structure, events that are recorded, in what order they are recorded, errors that are recorded, possible meaning of the error codes, how much time or impressions it stores, if it has any size limit,…)
For example… this last log, I have not been able to attach it because it occupies 12 MB, and the forum has a limit of 8…
Can you limit the file size?
Do I have to delete it manually from time to time?
Maybe there is a plugin for its management…
