Klipper Parsing Error
Hi all,
Klipper/Fluid first time user here. Ive set it all up on my delta running a Radds/Due conmbo. Im setting up the printer config but when i save it, i get:
Unable to parse option ‘max_temp’ in section ‘heater_bed’
printer.cfg (5.8 KB)
I have refernced the RADDS example config and im not sure where im going wrong. If i comment out all of the hearter_bed section, i get a parsing error on the next section up and so on ans so forth.
Alex
It’s much easier to read these files if you upload rather than copy/paste. That said, you have a couple typos in your bed section.
min_temp:0
max_temp:130
These need to have spaces.
min_temp: 0
max_temp: 130
Thanks jakep_82. I also found i had some words just befor ethe fan pin entry which were stuffing it up.
Sorry about the config, the upload icon is different to the normal paperclip one so I missed it. I will use it from now on.
