siboor switchwire
SKR mini E3 v3
klippy (2).log (341.3 KB)
i keep getting an error ( Unable to parse option ‘max_temp’ in section ‘heater_bed’ )
and many others
and would like if someone could help me get my printer up and running
siboor switchwire
SKR mini E3 v3
and many others
Hello @AgK9132 !
Your config file seems to be a bit mashed up.
Please attach the printer.cfg to your next post.
@AgK9132 as Eddy requested, please attach your printer.cfg and DO NOT paste it into the message.
printer.cfg (10.9 KB)
thank you two so much and insight would be perfect
Welcome AgK9132,
Probably the space sign before ‘max_temp’ in section ‘heater_bed’ in line 214 of your ‘printer.cfg’. Just a typo ![]()
One question, is this your first Klipper printer?
# Displays
## For the mini12864 Display, the [display] and [neopixel] must be uncommented
mini12864 LCD Display
connected to exp1/2
[display]
# mini12864 LCD Display
lcd_type: uc1701
cs_pin: PB8
a0_pin: PB15
rst_pin: PB9
encoder_pins: ^PA9,^PA10
click_pin: ^!PB5
contrast: 63
spi_software_sclk_pin: PA5
spi_software_mosi_pin: PA7
spi_software_miso_pin: PA6
menu_reverse_navigation: True
Lines 5 and 6 need to be commented out.
# Probe
#Z Max Connector on Z(main) Board
Inductive Probe
[probe]
## If your probe is NO instead of NC, add change pin to !z:P1.24
pin: ^PC2
x_offset: 0
y_offset: 25
z_offset: 0
samples: 3
samples_result: median
sample_retract_dist: 3
samples_tolerance: 0.006
samples_tolerance_retries: 3
Same here on line 7
# Extruder Settings
#Motor - EM
# E0_STEP_PIN PB3
# E0_DIR_PIN PB4
# E0_ENABLE_PIN PB1
# E0_UART_RX PC11
# E0_UART_TX PC10
step_pin: PB3
dir_pin: PB4
enable_pin: !PD1
## Update value below when you perform extruder calibration
## If you ask for 100mm of filament, but in reality it is 98mm:
## rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
## 22.6789511 is a good starting point
rotation_distance: 4.637 #Bondtech 5mm Drive Gears
## Update Gear Ratio depending on your Extruder Type
## Use 50:10 for Stealthburner/Clockwork 2
## Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
## Use 80:20 for M4, M3.1
gear_ratio: 7.5:1
full_steps_per_rotation: 200
nozzle_diameter: 0.400
filament_diameter: 1.75
heater_pin: PC8
## Validate the following thermistor type to make sure it is correct
## See https://www.klipper3d.org/Config_Reference.html#common-thermistors for additional options
sensor_type: Generic 3950
sensor_pin: PA0
min_temp: 10
max_temp: 270
max_power: 1.0
min_extrude_temp: 170
control: pid
pid_kp: 26.213
pid_ki: 1.304
pid_kd: 131.721
#Set appropriate once tuning your printer
pressure_advance: .025
## Default is 0.040, leave stock
# pressure_advance_smooth_time: 0.040
max_extrude_only_distance: 500.0
max_extrude_only_velocity: 120
On line 34 you have to delete the leading space
# Y Stepper Settings
# Motor -YM
# Endstop - Y-STOP
[stepper_y]
step_pin: PB10
dir_pin: PB2
enable_pin: !PB11
rotation_distance: 20.0
## Ucomment one of the following:
# Switch-based endstop for Y
#endstop_pin: ^PC1
Sensorless endstop for Y
endstop_pin: tmc2209_stepper_y:virtual_endstop
homing_retract_dist: 0 # Uncomment this line too
position_endstop: 250
position_min: 0
position_max: 250
homing_speed: 70
homing_positive_dir: true
Line 19 needs to be commented out.
# X Stepper Settings
# Motor -XM
# Endstop - X-STOP
[stepper_x]
step_pin: PB10
dir_pin: PB2
enable_pin: !PB11
# Switch-based endstop for X
#endstop_pin: ^PC1
Sensorless endstop for X
endstop_pin: tmc2209_stepper_x:virtual_endstop
position_endstop: 220
position_min: 0
position_max: 220
homing_speed: 70
Same here on line 18
# Bed Heater
# BED Connector
[heater_bed]
heater_pin: PC9
sensor_pin: PC4
control: pid
# tuned for stock hardware with 50 degree Celsius target
#pid_Kp: 54.027
#pid_Ki: 0.770
#pid_Kd: 948.182
min_temp: 10
max_temp: 110
The leading space in line 18 has to be deleted.
I have try deleting that space infront of the max_temp and it still reads the same error
This is also my first klipper printer
all changes you have mentioned i have changed i saved but now no errors
many thanks
how do i get the klipper bin file to flash my fireware
Please review Klipper Documentation for board setup.
