Printer Model: Ender 3v2
MCU / Printerboard: 4.2.2
klippy.log (53.9 KB)
Where did you get that config file from? I’ve never seen a config file that uses ‘=’ to assign attributes in the config file before. I don’t know if that’s the error or not, however it’s the only thing I can see that doesn’t look right, and the error in the log file is that klipper is throwing an exception while reading and parsing the config file, so that would be consistent.
So, instead of doing “max_temp = 130”, try doing “max_temp: 130” and see if that fixes the problem
My mistake, sorry about that
Please attach your original printer.cfg
printer.cfg (2.0 KB)
Thanks so much, don’t know how I missed that!!
