Currently having this issue after fixing my old Neptune 3 Pro, the disconnects are completely random, sometimes while idle, other while in a print. Printer firmware and cfg is from TheFeral Engineer, RPI is running MainsailOS 2.2.2
Already tried 2 usb b cables
RPI Powered by the internal PSU with a buck converter at 5.3V
seems to be doing it less after updating the firmware on my printer and replacing the usb cable with one that has a ferrite core, any other suggestions?
Also, one thing that happens is that I need to do a firmware reboot twice to get the printer working, 2nd error is “Can not update MCU ‘mcu’ config as it is shutdown”
