MCU disconnects mid print
So basically like it will just randomly disconnect from my klipper mid-print, I also noticed a while ago that it would also disconnect if I just left everything idle for a while, however I did do a lot of changes since then.
Here is what I’ve done so far:
Proper PSU *I was previously running a phone charger on pi but I fixed that, still idles out at like 90’ish %*
Different Cables (Specifically for data connection from ender 3 to rpi3)
Different USB ports on pi
Complete reinstallation of Both OS and Printer firmware (But I did keep my same configs)
Technical Specifications
Printer: Ender 3 with 4.2.2 mainboard
Host: Rasperry pi 3 Model b Revision 1.2
UI: KlipperScreen + Fluidd
Printer.cfg
# This file contains pin mappings for the stock 2020 Creality Ender 3
# V2. To use this config, during “make menuconfig” select the
# STM32F103 with a “28KiB bootloader” and serial (on USART1 PA10/PA9)
# communication.
# If you prefer a direct serial connection, in “make menuconfig”
# select “Enable extra low-level configuration options” and select
# serial (on USART3 PB11/PB10), which is broken out on the 10 pin IDC
# cable used for the LCD module as follows:
# 3: Tx, 4: Rx, 9: GND, 10: VCC
# Flash this firmware by copying “out/klipper.bin” to a SD card and
# turning on the printer with the card inserted. The firmware
# filename must end in “.bin” and must not match the last filename
# that was flashed.
[include fluidd.cfg]
[include macros.cfg]
#[include Adaptive_Meshing.cfg]
#CR-Touch Config
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: 0
position_max: 235
homing_speed: 50
second_homing_speed: 5
[temperature_sensor MCU]
sensor_type: temperature_mcu
min_temp: 0
max_temp: 100
[temperature_sensor Pi]
sensor_type: temperature_host
min_temp: 0
max_temp: 80
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
endstop_pin: ^PA6
position_endstop: 0
position_max: 235
homing_speed: 40
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
rotation_distance: 8
#position_endstop: 0.29
position_min: -3
position_max: 250
homing_speed: 50
[bltouch]
sensor_pin: ^PB1
control_pin: PB0
x_offset: -43
y_offset: -10
samples: 2
speed: 2
#z_offset: 0.0
[safe_z_home]
home_xy_position: 117.5,117.5
speed: 50
z_hop: 10
z_hop_speed: 5
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 15, 15
mesh_max: 188, 191 #this may need to be calibrated for your individual printer
probe_count: 5,5 #this is the number of probing points on X then Y axis
algorithm: bicubic
mesh_pps: 5,5
fade_start: 1
fade_end: 10
fade_target: 0
max_extrude_only_distance: 101.9
max_extrude_only_velocity: 120
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
rotation_distance: 34.406
nozzle_diameter: 1
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
# tuned for stock hardware with 200 degree Celsius target
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 250
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
control: pid
# tuned for stock hardware with 50 degree Celsius target
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[fan]
pin: PA0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
[display]
lcd_type: st7920
cs_pin: EXP1_7
sclk_pin: EXP1_6
sid_pin: EXP1_8
encoder_pins: ^EXP1_5, ^EXP1_3
click_pin: ^!EXP1_2
[output_pin beeper]
pin: EXP1_1
[board_pins]
aliases:
EXP1_1=PC6,EXP1_3=PB10,EXP1_5=PB14,EXP1_7=PB12,EXP1_9=,
EXP1_2=PB2,EXP1_4=PB11,EXP1_6=PB13,EXP1_8=PB15,EXP1_10=<5V>,
PROBE_IN=PB1,PROBE_OUT=PB0,FIL_RUNOUT=PA4
[display_status]
[exclude_object]
[bed_screws]
screw1: 27,209
screw2: 197,209
screw3: 197,38
screw4: 27,38
#Non-Touch Screen Extensions
# Rename Octoprint to Klipper
[menu __main __octoprint]
type: list
# Use Klipper commands
[menu __main __octoprint __pause]
type: command
enable: {printer.idle_timeout.state == “Printing”}
PAUSE
[menu __main __octoprint __resume]
type: command
enable: {not printer.idle_timeout.state == “Printing”}
RESUME
[menu __main __octoprint __abort]
type: command
CANCEL_PRINT
[include moonraker_obico_macros.cfg]
#*# [extruder]
#*# [heater_bed]
#*# [stepper_z]
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# -0.082500, -0.173750, -0.262500, -0.273750, -0.268750
#*# 0.037500, -0.053750, -0.133750, -0.141250, -0.153750
#*# 0.097500, 0.015000, -0.043750, -0.035000, -0.011250
#*# 0.153750, 0.086250, 0.048750, 0.082500, 0.112500
#*# -0.770000, -0.545000, -0.316250, -0.042500, 0.265000
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 5
#*# mesh_y_pps = 5
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 15.0
#*# max_x = 188.0
#*# min_y = 15.0
#*# max_y = 191.0
#*# [bltouch]
#*# z_offset = 1.650
Macros.cfg (Additional not Fluidd included routines)
[gcode_macro Part_Removal]
G1 X110 Y200 Z200
[gcode_macro START_PRINT]
description: Sys-USE - Set neccesary preprint values
BED_MESH_PROFILE LOAD=default
[gcode_macro END_PRINT]
description: “Print END Routine“
# Turn off heaters
M104 S0 ; Turn off extruder
M140 S0 ; Turn off bed
# Retract filament slightly
G91 ; Relative positioning
G1 E-2 F300 ; Retract 2mm filament
G90 ; Back to absolute positioning
# Turn off cooling fan
M107 ; Fan off
# Console notification
RESPOND PREFIX=“end_print” MSG=“Print finished. Cooling down hotend and bed…”
RESPOND PREFIX=“end_print” MSG=“Temperatures safe. Running PART_REMOVAL macro.”
PART_REMOVAL
[gcode_macro Preflight]
description: “A once in a while system upkeep routine”
PID_CALIBRATE HEATER=extruder TARGET=200
PID_CALIBRATE HEATER=heater_bed TARGET=60
[gcode_macro Lube_Priming]
description: Moves X-Axis up and down five times to adaquetly spread out Z-rod Lubricant
G1 X110 Z200
G28
G1 X110 Z200
G28
G1 X110 Z200
G28
G1 X110 Z200
G28
G1 X110 Z200
G28
(Oh also I did add a glass bed and CR touch) the CR touch does behave just fine so I don’t think it’s the culprit, but then again I am somewhat new so I may be wrong on that end.
Sorry, but 90% of your post is not relevant and does not help to diagnose anything.
Start over, follow the template and How-To Ask for Help
