Printer Model: Voron V0.2 Fysetc
MCU / Printerboard: Cheetah V3.0
Dear All,
Recently, I built a Voron 0.2 Fysetc with Chetaah 3.0 and Mellow PI as an SBC, and after some time, the printing printer halted.
I’ve checked the log file and found this issue:
Attempting MCU ‘mcu’ reset command
b’Got EOF when reading from device’
Attempting MCU ‘display’ reset command
Attempting MCU ‘host’ config_reset command
webhooks client 281473433028448: Disconnected
Restarting printer
Things that I tried to solve the issue:
-Rebuild firmware from scratch
-Change all USB Cables 3 times.
-Disconnected V0 display and disabled on firmware
-Change SBC, replaced by BTT PI
-Tested Power Supply under load, and no fault was found
-MCU and SBC have independent fans. MCU and SBC temperatures did not rise above 50 degrees Celsius
Best Regards,
Christian Brito
klippy.log (5.2 MB)
moonraker.log (16.2 KB)
